bugs
My md2020 has been slow to start since last year's filter changes. It started immediatelyprior to the change. I reseated the filters without success and hoped that this seasons new filters and rings would solve the problem but alas.
The tank is below the engine.
The water trap/1st filter is the highest point and seem ok. When i remove the bleed screw fuel pours out (especially if i glance away!).
The second filter may be the issue, when I use the priming pump i get fuel to squirt out. Ive loosened the injectors and get fuel to come out.
It takes a lot of turning over to get going.
Once running it restarts immediately after a short shutdown period but after a day or so it becomes very difficult again.
Is there a way of finding where the leak may be. I have one copper washer i want to replace onm secondary filter (i am aware of annealing but it is scraped) which may help.
Might it be an injector problem?
Im pretty sure the glow plugs are ok.
in frustration!
h
in frustration!
h
