how do I convert a soldering iron to a hot knife
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I have an old sodering iron lying around the garage. I thought it would be useful to convert it to a hot knife for lines. Is there a simple way to do this? What should I make the "blade" from
TS
I would have thought that any blade shaped piece of metal would be fine..it's hardly a Hi-tech application.
Come to think about it; I think I've got a spare soldering iron in my shed. Mmmmm.......Good idea.
(PS. I liked the spelling of "sodering"! :)
If you already have the soldering gun, use some solid electrical wire bent in a U instead of the normal tip, hammer it flat after bending. Works a treat.
An instant heat soldering 'gun' from Lidl (Park Side). It comes with a rope cutting blade and costs around €12.
Having never bought from Lidl previously I find the site incomprehensible. Is this deliberate so that one has to go to the shop not knowing what they stock?
A hot knife for £12 seems a bargain
TS
I converted a 75 watt iron to a hot knife some time ago, and posted photos, but honestly the cheap Lidl iron with a knife blade is much better.
TS
I have two of the Aldi version one on the boat and one at home, same price and well worth the cash. You should try them both, there is a lot of good stuff in there
If you convert the soldering iron, I suggest you only use a copper tip and ham,mer it flat into a knofe edge. I thought I was doing this with a copper rod, which turned out to be a copper COATED steel rod! It worked fine but the steel will not dissipate the heat as does copper and my iron element burnt out!
