daveyjones
I am restoring an old wreck of a ketch which came without spars, photos or drawings. I want to build new masts, but I don't know how to work out the correct thickness. I know there is stuff on the web about this, but it seems you need to be a mathematical genius to understand it- righting moments, forsooth!
Here are the relevant figures: both mizzen and main will be hollow sitka spruce spars,(solid at stress points) epoxy glued in an 8 part birdsmouth arrangement, and tapered. Wall thickness will be 22.5% throughout the length (ie the thickness of the staves composing the mast will be just under a quarter of the mast diameter, and the staves will taper upwards to reduce the mast diameter but retain the wall/diameter ratio). Both stepped on the keel and chocked at deck level. Main is 34ft from deck to mast head, mizzen 25ft. Gaff rig on both, mainsail is 250 sq. ft , jib about 160 sq ft, staysail about 100 sq ft. Mizzen sail about 125 sq ft. I am not planning to have a topsail at the moment.
Boat is a fairly typical long keel heavy displacement type, 34 ft loa, 10 ft beam, 6ft draft, weight probably about 7/8 tons (just a guess), ballast keel about 3 tons (another guess).
What I would really like to know is how thick the masts should be at deck level. I am guessing that 7ins would be about right for the main, and 5ins for the mizzen. Any comments? Better yet, does anyone have or know of a similar yacht and what size its masts are? Thanks in advance for any contributions.
