demonboy
I've currently no sink in my galley which is offering me an opportunity to improve the air circulation of my two Danfoss compressors that sit in the cupboard underneath. They're both the same but for the sake of argument I call one my fridge and one my freezer, which sit on separate shelves. The cupboard door has a grille in it, supposedly to allow the hot air out but I'm sure I can improve the circulation somehow.
Here you can see from above how they have been installed. The compressor sits inside the boat and the condenser faces towards the hull, with the fan blowing towards the hull.
From the side you can see that the freezer compressor sits further in towards the boat and the fridge compressor, on the upper shelf, closer to the hull. The arrow indicates the movement of air from the fan between the compressor and the condenser.
And a view from the front with the door open (the closed door would have the grille somewhere in the middle.
My concern is that the hot air generated by the compressors is only being circulated within the cupboard with little escaping through the grille. My first thought was a fan on the back of the door so the hot air gets sucked out from the cupboard, through the grille and into the galley.
Another thought would be to run some kind of conduit from the condenser, but that's a bit more involved. If I did that, I'm not sure how much of the condenser/fan I could cover, if at all.
I did think about turning them around so the hot air is being blown straight at the door, but that's even more involved and requires extending and brazing new copper pipes.
Finally, there is a narrow cupboard to the left which houses a small rubbish bin and shelves. I wondered if putting a fan between the two would help, but can't decide if a) that would be any use and b) which way the fan should point (i.e. get hot air out or bring cold air in).
Any pointers/ideas gratefully received.
Thanks in advance.
Thanks in advance.
