dougg
The hot water stabilization has all gone to pot on our Jeanneau 42.
It used to be the case that we got a nice even temperature of water when showering.
However the temperature now fluctuates as the pump kicks in and out, ie when the pump cuts out the temperature of the water is to hot to stand under, then, when the pump cuts in again, the temp is fine for the next few seconds until the pump stops and so on.
As the pump feeds the cold water system and in turn the cold feed to the hot water cylinder, surely this will be balanced pressure hot and cold??
