RichardPerou
I have to change the piping on a heat exchanger. Tec data tells me that the operating temperature is quite low. There will be some very tight bends. What should I use?
Ordinary car heater hose, although you may not find it takes kindly to tight bends where a moulded hose was probably fitted.I have to change the piping on a heat exchanger. Tec data tells me that the operating temperature is quite low. There will be some very tight bends. What should I use?
