tamarix
Active Member
How hot should a prop shaft get?.........or should it get hot at all?
I assuming you have a prop shaft which goes from the gearbox through the stuffing box and to the prop, the shaft being held in place with a A or P bracket close to the prop.
One cause of heat in the stuffing box is if the face plate has been tightened too much, placing too much pressure on the stuffing making it too tight around the shaft preventing proper cooling from sea water and overheating. When not turning, you should have a drip every second leaking through.
A normal heat would be a max of around 25C max. Any more than this might start to cook the grease in the stuffing making it brittle and friable thereby losing its watertightness. Nasty.
Another cause could be an out of alignment shaft.
Needs investigation.
