catlotion
I've recently purchased a new Honwave T30-AE3 and tonight I was about to fit some wheels.
However, on measuring up I've discovered that the engine plate on the transom isn't centred. It's 12mm offset.
Not hugely clear in the photo but if you look at the triangular gap between the tape and plate you can see difference. Also the alignment with drain hole is off.
I've taken loads of measurements from different reference points and it's definitely out.
Not sure what to do. I suppose it won't make a difference to engine drive but it's a bit annoying for a £1000 boat.
Has anyone else experienced similar issues? Am I being fussy?
