Honwave inflatable floor questions/problem ?
Oscarpop
31 Jul 2011
Kent
We have a honwave 24 inflatable floored tender.
The inflatable floor seems to lose pressure over a period of weeks. The dinghy tubes however lose no air.
I am fairly sure it's not a puncture, as I believe it would deflate faster
I went to see the honda people at the boat show and they said that there is normally some sand or grit in the valve which allows air out. However I've checked both and they seem clear.
We have a paddle board which is inflated to 25 psi, and that loses no air, so I don't think its the increased pressure in the floor.
Any ideas?
Ta
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
Any ideas?
Ta
Not trying to be clever but if it's loosing pressure it must be loosing air.
The only way you will find where is through bubbles so I would pump it up to it's maximum pressure and then fill the tender with water until the floor, seams and valves are completely covered. Then watch very closely for an hour or so. A bit of washing up liquid will help the bubble, and it might be one bubble every few seconds, to stick around a bit longer.
If you see nothing you have to do the other side. More difficult so even more washing up liquid in all the hollows and more patience required.
Richard
Oscarpop
31 Jul 2011
Kent
I agree that checks for a leak is the next stage. However, two things make me think that it's not a puncture. First, we punctured ( accidentally) a lilo with a pin last year. The lilo was no where near as high a pressure as the honda floor, and it deflated far faster than the Honda.
Secondly, the Honda floor has 2 independent sides, with two valves. They both deflate, so we would need to have 2 punctures.
Oscarpop
31 Jul 2011
Kent
It's 3 years old.
Some more research on he Internet, and apparently you need to tighten the valves, using a tool which I have now found in the repair kit.
I found a video on how to remove, clean and the. Tighten the valves.
I didn't kniw you could do his.
http://youtu.be/sXSdzpzfMS0
There you go
typhoonNige
29 Aug 2006
Lymington
It's 3 years old.
There you go
Our ageing Waveline dinghy was recently given a reprieve from the skip after I removed and cleaned all the valves. It still looks carp and is sticky but it hasn't needed the pump for over a week now. I also put a very thin smear of silicone grease over the valve o-rings and seals after cleaning. As i didn't have the valve removal tool I used the opened jaws of my snipe nosed pliers to undo the valves. Risky perhaps, but it worked
Trop Cher
17 Aug 2007
The Minch
It's 3 years old.
There you go
That's interesting as the floor on my Honwave loses air/pressure also, generally within a week, but I don't recognise the tool used in the video. I'll have to have a look in the wee tool pouch.
Please let us know how you get on.
HenryEDM
21 Aug 2013
Felinheli, N Wales
The honwave tool is a plastic wrench that fits inside the valve rather than a metal spanner like the on in the video
Lakesailor
15 Feb 2005
Near Here
Does this help?
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
That's an interesting one. We have a SunSport ARIB, same construction as the Honwave. One of our hulls has recently deflated, definitely no puncture. I will have a look at the valve.
