Denngeor
New Member
Where is the fuel filter located and how do you access it? My ‘04 is occasionally shutting down at high speed. I suspect that is the issue. This question was asked by another member in May ‘10 but, it was not answered.
Incorporated into the fuel tank outletWhere is the fuel filter located and how do you access it? My ‘04 is occasionally shutting down at high speed. I suspect that is the issue. This question was asked by another member in May ‘10 but, it was not answered.
That's the filter referred to in # 3 and by the OP himself in #5There is a small push in filter where the fuel line goes into the bottom of the tank, or at least there should be.
100% sure as I had it apart just before xmas when I gave the whole fuel system a scrub and polish.
Regards Clive
If youre using your engine weekly , periodically drain the bowl of your carb. If youre storing your engine for a few weeks at a time drain the carb every time prior to storage
