Honda 10hp
bellamia
13 Sep 2003
tamworth staffs
I'm using a Honda 10hp (B100) on my Evolution, there is an electrical conection on the side by the gear lever is this for charging the battery? Any other information about this engine would be appreciated, thanks
the_wanderer
8 Apr 2003
Provided there is a rectifier fitted in the engine, (a thing with fins on and wires running to the plug) then it will charge the battery at approximately four amps at medium throttle. If the wires come straight from under the flywheel to the plug then you only have alternating current which will not charge the battery. Have a chat with Maplin's. They may be able to supply the bits to construct a full wave rectifier at a fraction of the cost Honda will charge if this is the case.
oldharry
30 May 2001
Honda BF100s were fitted with rectifiers as standard. To be certain: there should be red and black wires leading from the socket back to a smallish box inside the casing. This in turn should have two green wires going to a lighting coil inside the flywheel asemply. There should be a 5 amp in line fuse between the rectifier and the socket.
If there is only a black wire to the socket, and the other side goes to an earthing point, then the connector is for a remote stop switch, but these were not fitted as standard.
bellamia
13 Sep 2003
tamworth staffs
THANKS FOR YOUR HELP, SORRY FOR DELAY GETTING BACK. IVE HAD A LOOK & THERE IS A RECTIFIER FITTED TO THE ENGINE AS WAS DESCRIBED. SO I JUST RUN THOSE WIRES TO THE BATERY KNOW FOR GHARGING
MANY THANKS
