Allan
I want to reduce the flow of water going into my combination boiler. At present it's struggling to cope with the 14ltr/hr. The spec says 12ltr/hr. I'm not sure what type of valve will give me the finest adjustment. The pipe is 15mm. Two I've looked at are below but the names gate valve and stopcock make the seem like they are designed to be on or off, not a gradual setting.
Gate Valve 15mm
Stopcock 15mm
I had thought of a pressure valve but want to keep as much pressure, just reduce the flow.
Honeywell Pressure Reducing Valve x
Allan
Gate Valve 15mm
Stopcock 15mm
Allan
