I am currently building myself an 11' double chine 2 part nesting dinghy using fibreglass panels stitched and laminated together. She will stow in 6' of length and there are 2 ring frames (with a waterproof gasket between) for joining the two halves together. My plan is to stow it upside down over the companionway on our Challenger 35, effectively forming a hood type of dodger (hence her name is the Dodger Dink). Hope it works!
There's also the PBO pup - plans available through PBO.
I have built the Fyne Boat Kits Eastport and Elterwater Prams - both good, and will take a simple sailing rig.
Good luck - it's a really nice winter project, altho' be careful using epoxy in low temperatures - you will need some heat to ensure curing without bloom, and it's essential that it is not to thick and cold when applied.
Had a look at the Bateau 2 site, really well done and with a help forum as well - I have always been tempted to build a boat...............I am starting to run out of excuses!
I like this one (a PK78 - nearly 8 foot)
But I suspect anything I built would not look quite the same!!
I missed the Sig. Doh /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
"The hull can be build in 80 hours but a finished boat will require 200 hours"
How are you doing???
How do you find the plans? / support from their website?? is it all as good as it looks?? For me the website looks well done and the descriptions clear (and make everything seem very simple!) - I had quite an enjoyable look through the site, some good looking boats.
Is the Venice Taxi the next project???!!
I wouldn't say they are wrong about the build time, but they are optimistic... I'm at the end of my second summer of building (in the garden, so no building in winter). I think by "finished hull" they don't mean faired and painted - that took me the best part of two months, part time..
The plans are good. Simple, easy to read, easy to transfer to wood, easy to understand - I built a model first which helped a lot in understanding how it all goes together. On a 17 foot hull, I "mis-aligned" one side panel by 2mm. Easy to fix. I will be buying more plans from them.
I wonder if I can get discount for references??? /forums/images/graemlins/cool.gif
Support is good on the forum - even so called stupid questions will get an answer, but they can be a bit picky about being off-topic (unless it involves fishing... /forums/images/graemlins/crazy.gif)
I'd love to build the Maia-24, but the current plan is to build lots of little 14-footers...
The Venice taxi was to show how I'd like my deck to look when done. Wishful thinking...
