scrambledegg
Sorry if my title's a bit melodramatic. The humdrum truth is I've taken off the stern seal and can't find a replacement. Boat is on the hard, no imminent danger of sinking.
My dripless Volvo seal on my boat's 1" shaft gave up the ghost at the end of last season, not at all surprising as it was more than 15 years old. Problem is I can't find a replacement dripless seal that fits a 1" shaft and a 48mm (~1&7/8") o.d. stern tube, except ones that require a pressure water feed inlet and (in one case) outlet (such as PSS, DeepSeaSeal). Non-water-fed shaft seal offerings from Volvo and Radiche match a 1" shaft to 42 or 43mm o.d. tubes.
I just can't be the only one to hit this problem. I am boggled that Volvo etc make seals that fits just one diameter of stern tube. The original volvo seal on the boat has a part number that doesn't exist any more (888738) . I don't know if that seal actually fitted, or whether the original fitter just got very creative about fitting it.
Anyone out there found a good work-around for this?
Must I bite the bullet and arrange for a pressure water feed (how is that done)?
Thanks for any suggestion
