jfm
Our holding tank fills up in a couple of hours with no use. There is no sign of flush water leaking and filling it. However, the seacock in the discharge-to-sea pipe is normally left open. I am guessing therefore the non return valve (assuming there is one?) in the discharge pipe must be stuck open a bit.
Does this sound correct diagnosis? (I'm not on the boat currently, so doing this diagnosis by remote control) Any other ideas?. How are these non return valves constructed - is it a flap type valve and could some crud have got caught in it so preventing it closing/seating properly? Are they cheap plastic devices, so I should just buy one and take it down to swap it? The components are generally Sealand, and the discharge pipe is I guess 1.25 inch diameter approx, with a macerator pump, the usual set up. How many pairs of rubber gloves and gas masks will I need to do this job?
