bateau57
Active Member
Some background. My boat has a Lavac toilet which is very simple and has the usual Henderson MkV pump and works well. I have built the holding tank myself from ply, fiberglass and epoxy and its for under the V-berth. For the record, the tank has 10 coats of West System epoxy inside using 422 barrier additive plus fiberglass mat.
To install the waste system, some yachts I know use 2 Y-valves; 1st Y-valve to to control the pump source from either the toilet or the holding tank; the 2nd Y-valve is used to direct pump output to either the holding tank or overboard. As many will know in the Med finding pump out is difficult so the plan is to pump overboard where it is legal. This installation allows the source to be switched to holding tank and the output to be switched to overboard and covers all 3 use cases 1. Pump toilet waste overboard 2. Pump toilet waste to holding tank 3. Pump holding tank contents overboard
This all seems totally reasonable until you read the Jabsco Y-Valve instruction manual and then inspect the Y-valve. The Y-valve is directional, has a single input and 2 outputs and is really only to control the pump output from the instructions. The Jabsco Y-valve has direction arrows on the body of the unit. The Y-valve for the source would have the output connected to the source for the pump being either the toilet bowl or the holding tank thus the flow would be from the output to the input. The reverse flow to the arrows.
This 2 Y-valve setup seems to offer the simplest control options over the waste. The advantages are; It is simple (1st rule of robustness), one existing pump, no macerator pump or second pump required. The problem is this breaks the Jabsco rules in the instruction manual for installing the Y-valve.
My question then is this. In practice does this installation work Ok? Do you know of blockages or problems when installing the waste system this way? What are the other options?
