Neeves
We have a large 45^2m unstayed headsail on a bowsprit. Luff tension is produced by cranking up a 2:1 dyneema halyard. The luff itself is double dyneema. The sail stays rigged most of the time but we drop it if we have a longish period away from the boat or there is need for some TLC. The sail is on a furler with swivels top and bottom.
The halyard is terminated at the mast top, comes down to the swivel attached to the head of the sail, swivel is a grease filled, ball bearing race, returns to a sheave just above the termination point, down the mast to a mast based winch. Tension is applied when in use, that tension is reduced slightly when furling (and when the sail is furled).
We find that when we have had the sail down and re-hoist the halyard both twists, so the two part of the halyard, twists round each other and maybe more serious the portion passing through the sheave develops a hockle and the hockle grows (or becomes sufficiently serious) it will not pass through the sheave block. The hockle is maybe half a turn.
Current solution demands me at the mast head, take the tension off the halyard by supporting the head of the sail from the crane with a short strop - and then I can manually untwist the hockle and the twists between the 2 parts of the halyard. Once I have done the remedial work - the problem disappears until we take it down and then re-hoist.
We can mitigate the twisting of the 2 parts of the halyard by introducing a counter twist before lifting - but the hockle defeats us - and though I don't mind mastwork, at all, it is something of a nuisance.
The halyard is new, ish, and was not cheap and bought from the sailmaker who built the sail (well known, good reputation).
I'm inclined to blame the rope, the halyard, and that it has a slight twist in its construction and/or cordage is made specific for double halyard application.
Comments, and preferably remedies, would be most welcome.
Jonathan
Jonathan
