Ric
HMS Terror and Erebus were fitted with lifting props, driven by a converted steam locomotive engine, for their ill-fated final voyages. The props would only be lowered and fitted when needed, to avoid drag when sailing.
I have been unable to find any substantive information on how this mechanism might have worked.
What I have established is that the props were mounted in a sliding wooden frame which could be lowered down below the water line through a well. But then how would the shaft be engaged? Was it pushed through some sort of stuffing gland, until it engaged with the prop, and then the other end somehow attached to the gearbox?
It is quite difficult to imagine how such an arrangement could be seaworthy in a wooden square rigger as it would require substantial opening in the hull below the water line.
There are some fascinating videos of the wreck of Erebus on Youtube, but not enough detail. I do hope that they will eventually raise the wreck as it seems remarkably well preserved and in shallow water too.
