Noddy
Hello,
I'm replacing my VHF ariel this winter. I'm not endowed with any real understanding of how a radio works but:
I read a short article on VHF ariels. What I took from it was that the usual type of ariel (looks like a welding rod) is qiute low gain. This is because when a yacht heels the signal is spread of over a wider vertical angle so the ariel will be effective at greater angles of heel.
I sail a cat, so heeling is not an issue. (At 45 degrees I am not talking on the radio and may well need an underwater ariel if it gets any more exciting).
So, assuming the boat is the right way up, would a High gain ariel (looks like a 6ft white fishing rod) give me an advantage by focusing the signal into a narrower vertical beam.
Would this advantage be in both transmitting and receiving?
What sort of gain (forgive pun) would it give, and how does this compare to cost?
Thanks in advance
Paul
Thanks in advance
Paul
