davidpbo
Mercury 8HP 1989 vintage.
We have always had problems with controlling our boat when reversing. The outboard is offset to starboard which combines with the effect of prop wash. I have tried different props one was very good for thrust in reverse but unfortunately got lost when I left it on the car park at Largs having swapped it for one that was better for forward speed.
I have been doing some work on the engine and whilst ordering spares came across something called a high reverse thrust cup
It replaces the spacer between the prop and the prop nut. I believe it allows the propeller to slide on the splines such that when in reverse the prop moves back
and shuts off the exhaust exit through the centre of the prop meaning the prop is biting into less turbulent water, the exhaust would appear to exit from behind the prop.
When going forward the prop is pushed forward and the normal exhaust channel is open.
At least that is how I think it works, I am open to correction.
The fitting instructions are telling me to drill out the splines with a 13mm drill to a depth of 13mm. I can’t see why because when the prop is in reverse the cup would be seated tightly sealing the exhaust gasses anyway.
Anyone know whether I need to?
Is this the tool for removing the prop shaft etc. or the correct spacer with a fish line cutter?
Anyone know whether this part should be in there?
Not shown in manual, mechanic at outboard shop had no knowledge of it, I put it over what I know think is the line cutter last year but can't see what it does and wonder whether it is anything to do with this part of the engine.
Any input appreciated.
