Hiab and mast?
dgadee
13 Oct 2010
Can a hiab lift a boat with its mast up? 32 foot boat and planning to stay in a bit longer this winter to coppercoat. Club crane hire will not be available when I want to launch. So, do I have to remove the mast so that a hiab can lift me in next year?
B27
26 Jul 2023
HIABs come in all sorts of sizes.
It's not just the weight, but also how far they can move something.
And they are not all that great at lowering things below the level of the lorry.
I think you are wanting something pretty top end.
I would either get a definite offer from a particular bloke with a HIAB, or look at other solutions like putting the boat on a trolley when the other launch and then tractoring it down a slip at low tide.
Or go to a proper yard.
rogerthebodger
3 Nov 2001
My 20-ton steel boat was lifted with 2 Hiab's one at each end when we loaded it on to a trailer to move the boat for launch
Refueler
13 Sep 2008
Far away from hooray henrys
Of course it can ... lift point is just aft of mast - so only item that may be of interest is backstay(s).
Yes mast is down - but thats purely because she's then off on a road trip for repairs.
That HIAB is a 10ton unit designed for roof work .. so height is no problem.... Boat is 4 ton 25ft ... but truck co. has an artic with 30ton HIAB that could do same with my 38ft yacht (would need cradle though as its fin).
"And they are not all that great at lowering things below the level of the lorry." .... but using slings and chains as we do - lowering below truck bed to ground is no problem at all. I can launch boat with same gear ... once boat floats .. HIAB goes down a touch more - unhook slings and then HIAB up and away.
dgadee
13 Oct 2010
The mast will be removed. Club don't want a mast up if it's not going in with the other boats. Gets in the way of the crane.
