MapisM
I was suggested a tank with this stuff, as a replacement of an obsolete system.
Is that ok, or is there any better alternative these days?
TIA!
TIA!
Yep, that is the one to get. Is same as FM200. If it goes off it is clean and it doesn't kill you if you are in e/room. It is a "negative catalyst" in that once present @ 20% the chemical reaction of combustion stops. You still have 80% of air to breathe.I was suggested a tank with this stuff, as a replacement of an obsolete system.
TIA!
Just be cautious that they are non toxic unless burnt, when the secondary gases produced can be very very nasty - e.g. phosgene, hydrofluoric acid, etc. It is the burning that pyrolises (smothers) the flame that burnt them.Yep, that is the one to get. Is same as FM200. If it goes off it is clean and it doesn't kill you if you are in e/room. It is a "negative catalyst" in that once present @ 20% the chemical reaction of combustion stops. You still have 80% of air to breathe.
Correct me if I'm missing something, but that's not a concern if it goes off by mistake/malfunctioning (i.e. without any fire) while someone is in the e/r, I reckon?Just be cautious that they are non toxic unless burnt, when the secondary gases produced can be very very nasty - e.g. phosgene, hydrofluoric acid, etc. It is the burning that pyrolises (smothers) the flame that burnt them.
HFCs are non toxic and non flammable meaning they will not sustain a fire on their own, but they do degrade, e.g burn, in fire to provide the fire fighting characteristic. So you are quite safe with a reasonable exposure, but then are not oxygen so too much and you could be asphyxiated. So if it went off by accident then you should get yourself out, but not to panic if you took a breath of the stuff.Correct me if I'm missing something, but that's not a concern if it goes off by mistake/malfunctioning (i.e. without any fire) while someone is in the e/r, I reckon?
And pretty sure, I'd jump out of an e/r as quick as I can, if a fire would break out while I'm down there - and I wouldn't dream of going down during or right after a fire, either...![]()
