Twister_Ken
The boat is ashore. I pumped the bilge a couple of weeks back, just to see if there was anything there. There wasn't, but while pumping enthusiastically, there was a metallic click, and the pump handle suddenly felt as if it wasn't connected to anything.
I took the pump apart this weekend and found that the diaphragm is sandwiched between two metal plates which are connected to the pump actuator (that which is wiggled about by the handle). The outer of these two is held in place by a plastic nut, which screws a long way onto the actuator. The nut had unscrewed itself, allowing one plate to fall off, and stopping the diaphragm working. Fortunately, an easy fix, but how to stop it happening again? It's a plastic nut onto a plastic spindle, so I suspect loctite or similar won't work. I'm reluctant to drill through the spindle to put a pin through, in case a create a weak point which migh fracture. Any suggstions?
BTW, if you have a similar pump (Henderson Mk V, now marketed as the Whale Mk V universal) i'd suggest you remove teh inspection plate form time to time and make sure that the nut is firmly in place. It could be embarrassing if it fell apart when you were seiously in need of it.
Diag here:
http://www.whalepumps.com/popup.php?n=ex...;bgcolor=ffffff
The nut in question is the one nearest the artist, mor or less in line with the word 'diaphragm'.
Diag here:
