Beez Neez
New Member
I am fitting 12volt anchor windlass. Windlass motor has one positive and one negative wire.
Propose using lewmar dual direction contactor. The contactor has 3 brass posts on top marked as follows. F1 , F2, and Batt +. Also 3 connections for spade conectors( assume for the up/down switch) marked 1, -ve, 2.
I have been advised that because I have only the two wires coming from the motor then it can only be wired to raise the anchor. Is this assumption correct on the basis of what I have explained or if not can anyone advise me how to wire in order that anchor can be raised and lowered using the motor.
Any guidance very much appreciated
