SvenglishTommy
I'm having some trouble setting up my rig, I have read the Seldon guide which was very helpful, but there are still a few things I'm not sure of. My rig is a masthead rig, one set of inline spreaders, keel stepped mast, aft lower shrouds and a baby stay.
As far as the cap shrouds go I think I'm ok, although the main shrouds are 6mm and the lower shrouds are only 5mm. My first questions is 'is this normal?' and does it have an effect on how tightly they should be tensioned? (15% of breaking load sounds like an awful lot)
Secondly, how tight should the baby stay be? I know it is there to provide 'slight positive pre-bend' in the mast, but how tight should it be to achieve this. Also, the baby stay is currently unavailable due to the deck fitting passing away last season, is advisable to sail without it until I get around to fixing it? I'm a little worried at the moment as there is slight negative pre-bend without any real tension.
Finally, the forestay is not adjustable as it is an aluminium furling foil. So how do I adjust the tension? The backstay is a single wire until about 2 meters before the bottom, where it splits in two and is adjustable, there is a turnbuckle between the single line and the split as shown here...
How much tension should I apply using the turnbuckle with the udjuster in its most open position.
Any advice greatly appreciated.
Tommy
Tommy
