Reptile Smile
Hi all,
Had a bit of a bad one with an engine that's new to me. Was leaving Bristol Entrance Lock with this outboard pushing a Hurley 24/70. I was aware that the cooling stream wasn't much - sometimes a minor dribble, and sometimes just a few drops. The engine cut out just as I left, and I assumed it had overheated. The harbourmaster threw me a line, and there was a resulting scramble which resulted in success. Later, though, I found the fuel line wasn't connected. What I don't know was whether it had overheated (it started again shortly afterwards, and I used it to get back to my berth) or whether it just didn't have fuel, and I'd accidentally knocked the fuel line off and it was running off fuel in the carb bowl.
In any event, I've sold the boat and am selling the engine. I have a spare impellor but have never done this in an outboard. I presume it's in the lower section of the leg. Is this right? As opposed to being on the head section of the engine?
If so, could anyone look at the following pics and suggest what I should be doing? I've highlighted some likely looking bolts...
Note that B is the same as C, and E is where the cooling water exits the head.
Cheers all
Cheers all
