Flames
I am new to this forum so I'm hoping somebody can help me with a problem I have with my 36ft Sealine flybridge.
About 5 weeks ago my boat ran level and even at 3200rpm when on the plane. It then came out of the water to have new steering bushes fitted in both drives whilst the work was being done the engineer fitted a new cone clutch and spacer and split locking ring to the port leg.
After fitting new top and bottom seals, anodes, gear linkage cables and anti fouling the hull it went back into the water last week.
On testing at speed I found that the boat heeled over to starboard about 30 degrees down angle when getting up onto the plane. The water conditions was good with no real wind. I ran the boat both north and south over a 2 mile distance with the same results both ways. Strangely the trim tabs made no differance they wouldnt raise the starboard side. the only way I could get the boat to run level was to have one leg at -4 and the other at +4.
Now I know its not the tabs, I can see both working and they were tested out of the water.
I know its not the fuel as both gauges show even and the levels are the same as 5 weeks ago.
I know its not the water tank. I know its not the holding tank even though its fitted on the starboard side it is without doubt empty.
Both engines, Ad41s, appear to run the same with the turbos whistling.
The propellers are Volvo A6s and are in good condition. I can see through the water all 4 are there with the locking cones in place.
I am beginning to run out of ideas where to look next. So if anyone has experienced similar problems or if there is somebody with engineering expertise I would be most grateful for any advice.
Many thanks Dave.
Many thanks Dave.
