DistantDrum
I need help on a number of counts due to the discovery of sump oil in our main water tank. This has contaminated both hot and cold water systems. One theory is that we have been sabotaged and a person unknown has put oil and petrol down our filler pipe. However, so far I have extracted at least 10 litres of black sump oil. Engine and Generators connect to the hot water system but both are okay. Also the oil extracted smells very strongly of petrol so is not from the ship itself. Currently I am still flushing the system with a product called hydrobreak which should eat the oil, this has been a long process and although getting better there would seem to be a long way to go.
The help I need is as follows:
1. The water tank is part of the keel of the ship and from the drawing sits on top of a ballast tank, presumably full of lead. Has anyone heard of a practice where a ballast tank was filled with sump oil to prevent corrosion – Maybe we have a cracked weld and oil is seeping up into the water tank.
2. Has anyone any contacts from the, now defunked, steel boat builders, Croft Marine, Stratford upon Avon.
3. Has anyone had a problem like this before and what do you recommend.
Thanks in anticipation. We are stuck in Gibraltar until we get this problem resolved.
