Help - Simrad IS12 Wind Transducer
Jorodeta
18 Dec 2004
Just Ask, although I\'m probably lost again
Hi, I have just taken apart my trensducer to find the the rotary postion hall tensistors had worked loose on my last crossing and need replacing. Speed is fine, just Direction.
I would rather find a repalacement for the 4 pin SIP Hall effect sensor, as then i can fix it again and reduce the same thing happening again as this type is well known to break at the body/lead connection.
Does anyone know the part number or have a circuit diagram for this or other IS12 parts?
Yes I could buy a new one, but only here, there not available elsewhere (see other posts) as they are discontinued - I therefore want to ensure i can keep it working no matter where in the world i am. Plus i like it, (NMEA2000/CAN) after changing from the old Stowe/Dataline system and dislike other makes.
David
