Neil
I have a Gibbs winch that is very stiff. I have taken off the circlip, removed the winch handle ratchet (pawl?), and the screw and washer. However, the body of the winch refused to lift off. Tried whacking it with a mallet. Tried to undo the nuts from underneath, but they are glassed over, and even when I expose a nut, the bolt just turns with the nut. I filled the 'cup' with diesel to let it soak (where does the water going into the winch handle hole drain to in normal circumstances?). I tried tying a rope around it and putting it over my shoulders, pushing up with my legs. What's left? Blow torch,? angle grinder and cut it off ?
Help!!!
Help!!!
