Seakale
Anyone know why my jabsco flush lite toilet only works on 1 of 4 on panel double flush. All wiring good & no corrosion
Many thanks for your response the only 1 that works is the double flush which leaves a dry bowlIn need of a new solenoid maybe? Which button(s) work (flush, fill drain, etc)? If "Drain/Dry Bowl" works, but "Fill or Flush" do not work, it is the solenoid. If so, easy fix.
Many thanks for your response. All the wiring is good and dry and no damp as i was able to pull the toilet forward and check.Mine had some small wire connectors at the back of the toilet. Basically the wires from the toilet to the panel It wasn't sealed very well and the damp had weakened the electrical connections. That's where mine failed.
Just wanted to let you know it was the Jabsco panel that was the fault. Unfortunately you are not able to buy it separately as you have to purchase the whole unit. Appreciate you trying to help me. Best Wishes. Bob.Many thanks for your response. All the wiring is good and dry and no damp as i was able to pull the toilet forward and check.
