Scubafill
While my boat is out of the water I have been advised to replace the cutlass bearings on my Hunter 26 (1990) as there is about 1/16" movement. (Sorry still imperial)
I have no idea on the correct procedure. I have searched the forum but can not find any info specifically about Hunter 26.
The bearings (2 I think) are secured in place by grub screws. Do I have to remove the shaft or do I just remove the prop and slide the bearings along the shaft (some hope). The prop shaft is 22mm (Metric !!) and is in very good condition.
How do I remove the prop? Do I need a puller or can I tap it off with a nylon hammer?
She goes back into the water on 16th March so I must rectify this urgently and I don't really want to pay a marine enginner.
Phil
Phil
