hullabaloo
hello
help please, i have a drip into the inside transom on one of my bravo 3 legs (1 drip ever 30 seconds), which turns into a faster drip when the engine is running (1 drip every second),
the drip is above the drive / bellows, and may be around or below the steering arm.
the boat was out of the water 8 weeks ago and i requested the boat engineer to cheak the legs, bellows and change the oil in the legs,
the leak seems to be above white drive shaft, right of the 2 bolts , below the red and blue wire,
any ideas?
thanks you,
any ideas?
thanks you,
