Danny Jo
Help please - battery 1 shows 12.5 V but won\'t turn engine.
Someone will no doubt tell me I did it wrong, but I drained my engine oil while the engine (Perkins Perama 29 hp) was still hot, but before I had secured a supply of fresh oil. So I went back a fortnight later, fitted new oil filter, added the necessary amount of oil, and turned the engine over (without starting it) on the service batteries (actually both battery 2 and battery 1), to pump the oil around. So far so good.
Then I thought, perhaps I ought to check that battery 1 was capable of doing what it was installed to do, act as an emergency starter battery. Battery 1 was showing 12.5 V (Mastervolt battery management system) but would not turn the engine. I noticed as I turned the key to first position (normal running) the ignition and oil pressure warning lights came on nice and bright, but they faded a little at the next, pre-heat position, and died altogether in the start position. At the same time the Mastervolt reading flashed "E".
My conclusion is that I must have a dodgy connection which can handle only a very low current. Has anyone got any thoughts on the most efficient way to troubleshoot this? The photo (edit - higher resolution version) below shows battery 1 fitted forward of, and slightly lower than the three batteries that make up battery 2. The back of the main switch is somewhere in the region of the bottom right of the photo. The batteries are gel type, dating from 2002, I think. I did a partial drop test of "battery 2" in April, aborting it at 160 Ah by which time the voltage had dropped to 11.5 V.
