help on biying new 8mm rubber flexbul gas hose
watermint
28 Jul 2010
by the sea
hurley-silhouette.blogspot.com
i am having a hell of a job finging 8mm gas hose , the gas hose is flexbull with copper ends swage on to the rubber flexbull gas hose and some is Armoured Stainless hose ?
Can I use 5/16" fittings on 8mm copper pipe?
shops seem to sell some metric, some imperial... a rough calculation makes them seem almost the same but the product descriptions don't mention it being the same as an 8mm fitting. this is for a gas fitting in a camper.
1/4" & 6m/m
5/16"& 8m/m
are compatible
Try B.E.S.. I used them when I recently did all my gas pipes on board and found them very good. Only issue was I had to buy straight sided copper "sleeves" for the compression fiuttings from force 4.
Mmmmmm!!
Can I respectfully suggest that making up your own gas piping with various fittings that may or may not be compatible might be a tad risky, not too say probably invalidating your insurance etc etc.
Would it not be better and safer to pay a few quid to someone who is registered for doing that type of work and then you, and the boats in the vicinity, will be able to sleep safe and sound? ;)
u tell me wher i can get a 8mm -to-5/16 COMPRESSION FITTING
but its saft to ues 5/16 pipe on a 8mm COMPRESSION FITTING
but u got to ues a new 5/16 ferrule on a 5/16 pipe and it will fit a 8mm COMPRESSION FITTING
thers is onley a mm difrent from 8mm -to-5/16 pipe if u can work that out
