HELP NEWBY
gra3333
New Member
11 Feb 2026
New to boats anyway my boat has a ford dover 4 cylinder the oil hoses blow off the gearbox oil cooler inlet then outlet what a need to know is with the gearbox oil cooler hoses off can i still start boat it will not be going into gear its a hydraulic gearbox to keep batterys charged and any help why my gearbox oil pipes are blowing off the inlet went first sorted that then the outlet oil pipe blow off 1 step forward 5 back any help at all would be great thanks graham
I don't know the specifics of your engine or gearbox but being pretty old I'd start by replacing the hoses and clips - I've seen a flap form on the inside of an old hose, causing it to block. Obviously check the cooler itself isn't blocked, but that wouldn't explain the outlet hose coming off. The only other thing I think of is an airlock in the cooler.
If this is occuring with the gearbox in neutral - easy enough to check - then you can't run the engine to charge the batteries until you've sorted it (or shortcircuited the cooler)
FWIW - you'll get more quality responses if you invest in some punctuation; you're making it unnecessarily hard for people to help you
Yes i replaced the first clip on the oil inlet on oil cooler started boat then the outlet oil pipe on oil cooler blow off so i dont think its the clips i wish it was my first thing to check was going to see if the oil cooler was blocked but with the outlet oil pipe blowing off has confused me the oil cooler is only for the gearbox the engine oil dose not mix with the gearbox oil thats why i thought i could start the boat as long as i leave it in neutral but thanks for your help i think i will have to i.d gearbox and see where the pressure valve is some one might of had the same issue i will look into the airlock thanks graham
Not familiar with the setup, but hoses blowing off in the raw water system is most likely excess pressure due to obstruction such as calcium build-up. If both inlet and outlet hoses blow off then I would look at what's next in the line - where does water go after the gearbox oil cooler? When were coolers last cleaned or acid flushed?
