Mark peter
New Member
Hi everybody, I was wondering if anybody could give me some advice or information that can help me to understand why performanse could be so bad during sea trials of a 76 foot cat that I was commissioned to do some basic works to, as the "new" boat was left on hardstand for 6 years before being launched recently. (Boat was seized by the courts untill all litigation issues were sorted out.
Scania motors 860 hp each, zf gearboxes,
I discovered that the left and right hand props were installed incorrectly and boat moved forward when I engaged reverse and moved backwards when I engaged forward position on the Teleflex electronic controller unit.
After swapping out the signal harness wires to the hydraulic solinoids ( F and R ) both engines.
We had the correct response as to direction, but I cannot believe the poor performance in power, handling (inability to use motors in opposite gears to swing the boat around at all. shaking,
no response to the boat when turning the rudders . The list goes on....
could there be a problem running the gearbox oppositly or are the props perhaps not supposed to work in opposite direction? Would appreciate any input or advise no matter how little.
Mark Peter
Mark Peter
