andy59
I have noticed this weekend that the starboard rudder tube is leaking about a litre per day and the lazzerette bilge pump is dutifully emptying it out but obviously I need to sort it . Does anyone know how to cure this problem ?. Rudders were removed and refitted for transport recently and both were fitted in the same way but only one is leaking . Is there some kind of seal or o ring that could be damaged ?. I cant see any grease nipples and the rudders had very slight play on survey but not enough to be problematic ( apparently ). Frustrating that a couple of inches higher and the tops of the tube would be above the waterline
Any advise gratefully received , boat is P42 BTW .
