help me find a Push fit Glass fuse Holder - pls
26 Apr 2010
the Cold North
So I have on of these panels
And the fuse holder (square in Red) has lost or snapped a locating peg.
Any ideas where to get the actual holder from ?
I have found these http://www.surplussales.com/Electrical/Holders/ElecHold-2.html
but from the USA.
Any ideas for here in the UK ?
26 Apr 2010
the Cold North
As a side note, and whilst having idle thoughts, it has crossed my mind that the Fuse Holder was poking out 4-5 mm when I found and quite stuck.
What would cause that? spring loaded fuse holder doesn't eject on overload does it ? the fuse wire just blows.
On the one in question, the Fuse is / was still 100% intact.
the Red cap had popped out a few millimetres, and in fact was a sod to fully extract out fully, eventually pinging across the cabin.
It seems the locating lug on the side of the red cap that you need to get a terminal screw driver to shift has sheared - hence I can't put it back in , and need new.
The question is: I am assuming they are just 'dumb' holders, and don't eject or anything fancy.
(I may be putting 24v through the 12v panel, BUT checking it out that only causes the LED rockers to get a little warmer, and Ironically the one that popped is feeding my 12v dropper unit)
