Help & Info on Volvo TAMD 22 P-B engine please
uncle phil
New Member
5 Nov 2013
South Wales
Hi All
Only just found this forum website so i'm looking for some help and info please,
I have a Merry Fisher 635 sombody has put a Volvo penta 105 in it.
I have only had the boat about 6 month it's on a trailer so i beach lauch with my 4x4,
i'm getting a few nigling problems and i want to sort a few things out,
Now i want to put a turbo boost gauge on her so do anybody know the boost presure the actuator shoud be opening the waste gate,
Also what is the best range of gauge should i get,
there will be more questions so please be patiant with me lol
Can't understand this forum ?? when you post i thought it would go to the top so members know it's a new post,
OH WELL:rolleyes::rolleyes:
As a new user your posts will not appear straight away, they will be checked by a moderator before appearing on the respective thread. I think this is what you were getting at, ignore me if I have misunderstood.
Mike.
Hi All
Thanks guy's for explaining that,
But can anybody help me with my question please,
you dont seem to be having much luck pity because i would be intrested in the same info because i got the same engine,
See if you can get the figure for the Rover Montego TDi. It's the same engine.
Thanks bobc
i have found out that it was fitted in the Maestro & Montego tdi's plus the sherpa vans but trying to get what the running and boost presure is on a gauge is like looking for rocking horse do do,
In a maestro workshop manuel it only states 135kpa = 1mm movment
Even my local Volvo dealers havent a clue what it should read on a gauge, :confused:
You could try ASAP supplies in Beccles. Alternatively VolvoPaul posts regularly on here and there is not much about Volvos that Paul is not familiar with.
Thanks bobc
Yes, I've got the same engine, and trying to get some of the right data for it is like pulling teeth.
I seem to remember that they give you a load pressure to set the waste gate valve to, but not an air pressure.
