lanerboy
hi all
i want to fit some snap davits to the transom on my s37 just above the rubbing strip, the problem i have is i wish to fit them off set so i can still get on / off the boat without the tender getting in the way.
i have been in the engine bay and there is a box section made from 1 inch ply that is part of the boats construction and i cannot get inside this box so i am unable to get any nuts on the bolts from the inside.
has anyone fitted any davits to the transom using self tapping style screws, i am worried about doing it this way as when inside the engine bay i can see the fibreglass is almost transparrent so therefor i doubt it will be strong enough to hold the weight of the tender and may give way and break off.
below is a pic of where i would like to fix the davits on the transom, the starboard side one is not a problem as i think i can get to the inside of this one to get some nuts on it but the port side one will end up inside the box section
below are some pics rafiki kindly took and sent me of a S37 with the same davits as mine but they have spaced theirs differently
