Help! Ignition broken advice needed
Eastanglian87
New Member
20 Jul 2012
Suffolk
Hi wanted to pick your brains and see if you could give any advice,
My ignition on the boat has failed , it turns to the first click , ignition/alt light comes on the dash, and then nothing .....
I am sure its just the ignition switch , starting it off the terminals on the starter motor is no problem at all......I really want to get fishing this weekend is there any way round this problem as a quick fix untill i can sort it out next weekend, do you think the alternator would still charge if i just started it off the terminals on the starter motor.
Even when i am starting off starter motor the alternator/ignition light stays on and doesnt go off...
I am pretty sure its not a prob with the alternator and just the switch, im useless with electrics any advice will be very much so appriciated.
Thanks in advance
