lumphammer
I have taken out the stainless shaft, which I had to do by cutting the shaft. I know have a small stainless stub sticking out of the boss that connects the shaft to the engine. The boss is about 4in long with a keyway machined to lack the shaft in place. Two allen bolts have been removed.
I have tried removing shaft by sitting shaft in a piece of scaffold pole so that boss sits on edge of pole, a small drift is placed on top of the other end of the shaft so that in theory I should be able to know the shaft into the scaffold pole. Lots of heat has been applied, then I hit the drift with a big sledge hammer!
No movement at all on the shaft!!
Any other suggestions as to how I might free this up?
TIA
Richard
TIA
Richard
