cpedw
I'm looking for a windlass to replace the manual Lofrans Royal on my Nordship 35 DS (35' 6 tons sloop, cruising West Scotland). The chain passes through a hawse pipe that slopes at a shallow angle into the chain locker where there's a big shelf with the Royal on it. I plan to put the electric windlass on that shelf.
I think a horizontal windlass is preferred because the motor needs to be enclosed, not exposed in the chain locker.
I don't have any use for a warping drum but I would like to have the option of manual operation and of taking the chain completely off the windlass. Some of the modern ones like Lofrans Atlas or Maxwell HRC 8 seem to completely enclose the chain. That doesn't seem like a good idea to me.
The hawse pipe is offset to starboard so keeping the chain line straight means there's not much space to the right of the windlass in the chain locker. That's where the manual operation happens on most of the windlasses I've looked at. The locker extends about 150mm under the deck to the right of the hatch opening.
I've looked at Lofrans Atlas, Cayman (tight fit in the space and pricey), Lewmar Pro 1000, H2, Maxwell HRC 8, Quick Genius GP2, Hector HC3 (another tight fit and pricey) and South Pacific 900m.
Apart from the South Pacific, these are either without manual operation or it's hard to access in my chain locker. The South Pacific seems to have non-credible performance (25A at 12V = 300W?) and limited information on the web. I haven't found any user reports either.
Can you suggest a windlass to match my requirements? Or are some of my specifications unreasonable or unnecessary? All non-libellous comments welcome.
Derek
Derek
