Helm Issues continued
Alz0r
New Member
24 Mar 2009
thanks for the replies all.
we've just been back onboard and we've narrowed the problem down to the piston arm that is attached to the rudder. It's a beta marine 25 inboard diesel engine by the way, with a "push and pull" steering system, with a cable inside a conduit.
Anyway there is a externally threaded tube in which a piston arm sits. A brass nut at the cable end holds the conduit in place (and with this nut removed, turning the wheel moves the piston back and forth - proving it's not a cable issue or a helm issue?).
We're assuming there's a spring attached to the end of the cable and to the piston arm (inside the threaded tube). There is also a ball which sits on the thread, and inside a clamp (with acts as the pivot / anchor point for the piston). But the piston arm isnt moving freely in and out of the threaded tube. We've hit it with a hammer with no movement, although it WILL rotate slightly and it feels like it's still attached to the spring.
We're stumped! Any thoughts?
Cheers /forums/images/graemlins/smile.gif
