Hella Anchor Light Bulb Replacement
petem
Cotswolds / Altea
www.fairlineownersclub.com
Another "Gardener's Question Time" post I'm afraid...
My anchor light isn't working. Hopefully it's just a blown bulb that I can replace with an LED equivalent.
Anyhow this is the light...
https://www.asap-supplies.com/navigation-light-all-round-white-12v-721127
Apparently "the bulb can be easily accessed and changed due to the 'snap lock' housing". Does anyone know how this 'snap lock' housing works?
I would put the light into a warm room to warm it up first as this makes the plastic more pliable and flexible.
The lens and cap are a single assembly that just rotate off the base.
Although bulbs obviously do go , last year I found 3 of my 4 imo lights not working .
Just fancied a pm test in the marina - just as well .
Plan was to disassemble and toggle off to marina chandler bulbs in hand .
Next morning- Two screws later off with the lens.
Tested power with a voltmeter all ok 24 V when switched on .
Eyeballed the bulbs - looked ok ,buts that’s not really a reliable test .Stuck a continuity tester on them - all 3 ok .
Hmm !
Went back to the units with a bit of emery paper , rubbed down the contacts a copper looking metal - refitted bulbs and rubbed down the point on the torpedo ends of the bulbs a plane grey looking base type metal - hey presto all worked .
Diagnosis = corroded slightly contacts - somewhere? , increased resistance for the 24 v to do much .
So every year now I open them up , clean the contacts and check the rubber gasket.
Surprising how dusty the inside of the lens becomes too .
Got a spare bulb which is itching to be used btw:)
well slightly better than my experience then!
after MiToS refit, nav light bulbs started burning at an alarming rate (as in 2 in 4-5h use) puzzled, replaced bulbs, same thing.
Got my specs on, checked the small print and sure enough they were 12V and not 24V, argh!
so now got 2 more 12V to give to one of the 12V guys in the pontoon and make sure I wont do the same mistake.
V.
Hmm !
Back in the days when I did boat PDIs one point was to apply vaseline to terminals of nav light bulbs and waxoyl wire ends and crimp connectors Prevention rather than cure was the motto.
Hmm !
You might like to try putting some Contralube on the contacts- it’s excellent stuff.
Right that's it. I'm going off grid for the whole month of May and I'm going to swap phones with Trevor and lose my iPads. Might see if I can get a last minute vacation in Kazakhstan :D
