ontheplane
Hiya,
Looking at a bunch of boats now, and all around 21' ish cuddies.
None have Fresh water cooling - so I assume I can't fit normal style heating. Also the boats a bit small for an ebespatcher (I'm sure that's not how you spell it) or so I assume.
We'd like to be able to cruise 12 months with covers up, so I'm looking for a cheap and simple way to heat the cockpit.
Issues I need to address -
1) Want a dry heat to prevent us steaming up under the covers - thus probably don't want anything that is alight such as a gas burner as it is likely to produce a lot of damp heat, plus see 2 below.
2) Have small children, so don't want anything they can touch that will be hot enough to burn them.
3) Needs to be super cheap and simple to fit.
I have a 2000W inverter - so I was thinking I could run a low powered fan heater but I can only see ones that the lowest setting is 1kw which is putting a huge load on the battery even with the engine running.
I have a halogen heater that runs at 400W which is nice - but the surface metal grille does get hot enough to be a concern with kids touching it.
Anyone got any other ideas?
