LittleSister
Does the shunt in the negative line for a battery monitor give off any significant heat?
I am considering the best location to mount the shunt for a battery monitor, and having limited space/options I'm considering mounting it under the fridge, but would not want heat being generated there.
It's a 500A shunt, but I don't have anything that consumes that amount of current. Biggest draw I have is for a small bow thruster, nominal 350A IIRC, and that would be used infrequently and only for brief bursts. In normal use the small fridge is the biggest draw, then autohelm, lights, domestic water pump, etc.
