Heat exchanger filler cap rubber Volvo Penta TMD22P
superboots
26 Feb 2002
Just spent an hour on google looking for the part number /seller for this simple but necessary item. The water cap on the top of the heat exchanger has pipe connections on top for expansion and return via a header tank. I've recently had the heat exchanger overhauled - minus the rubber profiled washer which effectively seals the system and allows the expanded water to flow. Has any one had experience to replace the washer - a new cap from VP is silly money - and not necessary. Perhaps if the correct part cannot be found - there's a u tube video showing a replacement ( but the source of the part was not revealed) double O rings might work
Is that the sealing ring , part number 1543751
If so only € 5.16
See the Marine parts Europe website
Sorry failed to post a link from this device
Thanks - after going back to the video I sussed the reference but the website didn't open properly - will try again later
