ShipsWoofy
- Joined
- 10 Sep 2004
- Messages
- 10,431
I am in the process of renewing my heads, rebuilding is a better word actually.
Currently we have a Whale V pump tap as below.
I would like to keep the manual tap in case of electrical problems etc. But would also like to fit a simple in-line water pump with a switch (not pressurised).
Does anyone know if I can run through this tap, using it like a normal caravan type tap with the option to pump should there be a fail. Or should I consider a Y joint and have two separate taps. I do know you can pump water through a simple in-line pump as our galley tap will run if I over fill the tank on that side.
Unfortunately the tap is on the boat and I am looking to put an order in today.
Any thoughts please?
